derfdog15 said:
I think the MBC route is a nice option for a car that may need fine tuning between the spring combinations, or for eaking out just a bit more power BUT as mentioned for a DD type of car, I think it may be overkill. Would be a nice option for a race-tune type of setup.
Per AJP's request, I am swapping to the 15.95 spring pressure combo, and running a slightly higher E percentage than I have been running. I will keep the thread updated once I get the next set of logging done. This is partially also to see some more insight can be shed on the predicament that MiWiAu has with his spring combos
Woot. Looking forward to your results!
At some point, I'm also planning to catalog the free length, spring rates, and install preloads of the springs in my kit. Tial hasn't been very helpful in providing nominal values, but at least we'll have a single point of reference.
Also, FYI, I ordered some parts to MacGyver (or possibly MacGruber) a spring preload adjuster for the Tial, but it will take some time to receive everything. I also need to measure the internal clearances on the MV-S from the diaphragm to the bottom side of the cap to see how much room I have for my mechanism when the valve is open and springs are compressed.
What I'm thinking is making a preload adjuster that will thread in through the center cap threads and interface only with the small diameter gate spring.
Using the alternative spring chart I posted earlier, every single Tial pressure option has an alternate spring combo that utilizes a small diameter spring. If this works, it would allow you to alter the spring preload on the small spring to fine tune the cracking pressure without having to modify the boost reference with a MBC.
Of course, this will only be possible if there is sufficient clearance in the gate once the valve has been actuated and the springs don't sack out when additional preload is added...
