My outlook on this...tell me if this makes any sense.StealBlueSho said:f8tlSHO said:I have a manual controller I am going to use also to dial it in.StealBlueSho said:Point is, don't bank on wastegate spring combinations by the spring chart alone, there is a reason for them developing the chart..
During Brad and my testing I needed around a 16.5 - 17 or so spring rate which is not available via the spring combinations.. verified when I called TiAL.. so that's when I threw on a manual boost controller..
Are you familiar enough with data logging and reading your own logs? There are several areas you need to monitor to tune for it.. map, tip, wgdc, rail pressure, and more.
And you need to monitor in real time...on a laptop...after each adjustment...or you can
mess stuff up...
If you are not confident in your ability to adjust the mbc based on what you are reading in the logs then don't do it. You are asking for trouble and most likely give Brad headaches...
I did not buy the same gate everyone else has. The springs in it are setup for 7,13,and20psi... If I use the 13psi spring and the mbc to adjust the pressure up to about 16 psi. My tune is only setup for 14psi at the moment. So I am not sure how limiting the boost below where the spikes are now is going to cause a problem. Am I thinking right? Or does this not make sense?
