f8tlSHO said:
I was looking for a boost reference line directly off the intake ( not intake piping) didn't see anything I could use....
I am putting the wastegate on, was wondering if I could just weld a fitting right on the tube attached to the wastegate. See picture, where the black dot is. Just wondering if this would be good or bad being so close to the wastegate
Interesting flange interfaces on that guy, particularly the connection to the bottom aluminum housing that contains the diaphragm. If you end up with any leaks, maybe consider reassembling with some RTV and thread locker on the screws.
While I wouldn't try using that in a traditional application, it may be just fine in this (much) less severe environment. Definitely interested to watch this evolve.
Do you have additional pictures or a link to the gate you bought? Curious if my idea for a Tial preload adjuster might work for this one as well. If so, might be a less expensive alternative to an auxiliary MBC. Could you take a couple of pictures of the internals as well, when you get a chance?
