PTU oil change write up?
The unit is water cooled on the PP, I believe, which doesn't necessitate additional capacity.
Same ridiculously low quantity throughout.
The Flex guys have issues with their PTUs as well, right?
Needmoreboost said:
I just got quoted $200.00 (Ford dealer) for PTU change/service.  What is everyone else paying?
i was just quoted $56 per differential by Sears Auto Center...
I seriously doubt if Sears understands the PTU in your MKS and I would be surprised if they have ever changed the gear lube in one.  Are you sure they aren't talking about differentials and transfer case on a 4X4 pickup?
my deaer quoted $130. I think but not sure if that was including the BG flush.
i told them the make and model of the car.
i'm going there this weekend, if there is an issue i'll let the forum know.
i think i'll also insist on them collecting the old fluid for me to take home...
Hey 68 I was under there last night also and it should be on the pass side of the PTU. I'll be honest I couldn't find it also lol. I did locate it easily on our Explorer (pass side about half way up the case). There is a write up with pics but it didn't help me when I was under the car. Maybe someone else that has done it on a PP can shed some light.
Here is the ford parts diagram, not much help. The drain plug and the breather is on there but not the fill plug.
Damn that sucks, I really wish I could help more. Did you drain the fluid yet?
interesting read. parts of a 2014 SHO PP owners manual
nformation Displays AWD Messages Change AWD Power Transfer Unit Lube 123 Action / Description ...when the AWD system needs its power transfer unit lubrication changed. This message may be set if a vehicle has experienced extended periods of extreme/severe duty cycle driving. See your authorized dealer for service. (Taurus SHO Performance Package Only) Action / Description Battery and Charging System Messages Check Charging System ...recovery. Contact your authorized dealer as soon as possible. Contact your authorized dealer as soon as possible. 2014 Taurus Owners Guide gf, 1st Printing, April ...
...any normal scheduled maintenance. Do not check or change the PTU lubricant unless the unit has been submerged in water or shows signs of leakage The Power Transfer Unit (PTU) in Taurus SHO™ performance package vehicles is... notifies the driver of required service by displaying the message Change AWD Power Transfer Unit Lube in... PTU lube will be more likely to require a fluid change if the vehicle has experienced extended periods... duty cycle driving. Do not check or change the PTU lubricant unless the unit has been... and to reset the PTU lube life monitor. 2014 Taurus Owners Guide gf, 1st ...
shoot no..... not until the fill is located.
I might just thrown in the town and pay the deal for it. Stinks to pay an extra $100 becasue I can't figure out how, or where to refill it !!!!!
the fluid change might be easier if I just took out the pass side down pipe maybe the turbo and maybe the CV axel, and several other things I have not clue what they are. It's crazy in there.
68gt be VERY careful with your car on ramps like that. It could easily roll backwards and fall off the ramps. Even with the emergency brake on.
Park another car behind yours pretty close just Incase it does decide to roll backwards.
I don't get under my cars much at all whille on stands period now days I only put it like that to get the car basically level with the front tires off in hopes that I could get the PTU fluid level to drain / fill. When I get partially under, or reach under etc I never touch the car, or wrench while under it, or let anyone touch the car. I also keep my big floor jack under there not pushing up, but just up to the car for extra holding.  And of course yes the e-brake is on. I only planned on looking around in the wheel well, so I give up. Thanks for looking out !
