Shoboat, fluid would have to pump in thru drain hole. Both device mention above could do this, with appropriate attachment to the end of thee hose to create a good seal when filling. Of course this procedure will be a little messy when reinstall drain plug. Another thing that could be done is to just install a small valve in the drain plug hole. Pump your oil in and close the valve.
